Directory watch on specific file
  • March 20, 2023
  • 117 views
iangr
Forum|alt.badge.img+4
Hi everyone,
I'm currently looking to use the Ressource or Network Directory trigger on FME Server automation to trigger a workbench when new file are added to a file.
The file type is DWG. With a DWG file, there is 3 other file that are attached to this file. How can I specify to the directory watcher to only look for new DWG file and not the attached file. Right now, my workspace is launch 4 time because of it.
Thank you in advance,
Ian
nielsgerrits
Forum|alt.badge.img+54
See Run a Workspace When Data Arrives in a Directory, step 3. You need to add a Filter.
