Directory and File Pathnames - multiple file extensions?
  • Oct 11, 2018 2:09 PM UTC
  • 6 replies
  • 393 views
bark0s
Forum|alt.badge.img+5
Is it possible to search for multiple file extensions in the one directory and file pathnames reader simultaneously?
Path Filter:
* - returns all files
*.dgn - returns all dgn files
*.dgn,*.shp - returns 0 results
Can someone please help me with the correct syntax for multiple file extensions in Path Filter?
Best answer by david_r
Try the following
*.{dgn,shp}
Make sure there are no spaces inside the braces.
Doc: http://docs.safe.com/fme/2018.1/html/FME_Desktop_Documentation/FME_ReadersWriters/path/PATH_reader.htm
  • Oct 11, 2018 2:47 PM UTC
Try the following
*.{dgn,shp}
danilo_fme
Forum|alt.badge.img+58
  • Oct 13, 2018 2:37 PM UTC
Try the following
*.{dgn,shp}
Excellent @david_r
  • Oct 15, 2018 9:09 AM UTC
Try the following
*.{dgn,shp}
Great to see an answer 3 days before I had the same question :-)
bark0s
  • Oct 15, 2018 9:13 AM UTC
Try the following
*.{dgn,shp}
Thanks very much, that worked like a charm!
achilles07
Participant
  • Participant
  • May 4, 2020 3:27 AM UTC
Try the following
*.{dgn,shp}
Thanks @david_r. Saved my precious time, as I didn't go through your document properly.
chriswilson
Forum|alt.badge.img+29
  • Sep 4, 2023 2:42 AM UTC
Try the following
*.{dgn,shp}
Just used this, thanks David for the tip.
