Difference between Esri Legacy SDE and Esri Geodb ArcSDE
  • Sep 30, 2017 3:37 PM UTC
  • 5 replies
  • 80 views
danilo_fme
Forum|alt.badge.img+58
My customer asked me about the difference between Esri Legacy SDE and Esri Geodb ArcSDE, when he wants to Reader SDE.
Thanks,
Danilo
Best answer by david_r
Also note that the Legacy SDE (called SDE30 internally) reader/writer has some particular limitations, search for "SDE30" on this page for more information:
https://knowledge.safe.com/articles/19440/comparison-of-fme-readers-and-writers-for-sde-and.html
On the flip side, in some instances it can be quite a lot faster than corresponding the ArcObjects readers/writers.
bruceharold
Forum|alt.badge.img+20
  • Oct 2, 2017 2:07 PM UTC
Hi, the legacy SDE format uses a C API that Esri no longer supports; in other words use at your own risk. The GeoDB SDE format uses an ArcObjects based API that is supported.
bruceharold
Robyn we miss you :-)
danilo_fme
  • Oct 2, 2017 2:17 PM UTC
Hi @bruceharold,
Thanks your reply and answer with this case.
Thanks,
Danilo
  • Oct 2, 2017 2:31 PM UTC
danilo_fme
  • Oct 2, 2017 2:58 PM UTC
Hi @david_r,
Many thanks your link sent me. I'll check it.
Thanks,
Danilo
