dgn translation to shape with Bentley Microstation geographics
  • Dec 30, 2019 7:43 AM UTC
  • 32 views
brigousse
Hello i want to translate DGN to shape with Bentley Microstation geographics
i have many dgn files like 1.dgn 2.dgn 3.dgn etc...
and many access files like 1.mdb 2.mdb 3.mdb etc... which are linked to dgn .
But when i use Bentley Microstation geographics source i can put all dgn files but only one mdb file.
Somebody can explain me how to do
Thank you
Forum|alt.badge.img+63
You can indeed only select 1 MDB file in the parameters. You can work around this by e.g. using a File/Pathname reader to read the names of all DGN files and then use a FeatureReader for every single one.
Set the FeatureReader to read Microstation Geographics, use the attribute path_windows as the Dataset and set the MDB file to
@Value(path_directory_windows)\@Value(path_rootname).mdb
