DGN Smart Solid - Solid interpolation to mesh
  • Apr 15, 2024 10:19 AM UTC
  • 239 views
boron013
Hello,
I’m working in FME Form (both tested in 2023.2 and 2024.0 ) with DGN files contaning 3D objects in Smart Solid format.
I’m looking for some possibility in controlling solid to mesh decimation process. At the moment I can’t find any way to change default way how FME Reader create mesh from solid objects.
For example some circular object is decimated as 8 vertices.
I’ve already tested Stroking Tolerance without any effect
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Stroking_Tolerance.htm
and “Number of interpolated curve vertices” in DGN Reader parametrs.
Any suggestions?
crystalatsafe
Forum|alt.badge.img+32
Hi @boron013
Just to confirm, are you wanting more than 8 vertices to have a smoother, more accurate curve?
Have you enabled the Preserve Curves parameter in the DGN Reader parameters? There's a chance this could impact the output and create a smoother curve.
Would you be able to send some sample data over so we can take a closer look?
Crystal
boron013
  • May 16, 2024 9:53 AM UTC
Exactly
Haven’t mentioned it in my post, but already tested it without any impact on result geometry.
You can find sample SmartSolid DGN in attachment
daveatsafe
Forum|alt.badge.img+24
  • May 16, 2024 5:23 PM UTC
Hi @boron013,
I’m sorry, but the resolution of the mesh generated from the SmartSolid is not currently controllable within FME. I have created an enhancement request to add a reader parameter to let users control this resolution (FMEENGINE-82813), and we will notify you when this has been implemented.
