Determine whether a shapefile has a Z and/or M
  • May 30, 2024 3:37 PM UTC
  • 155 views
regie_alam
Participant
What would be the best way (aside from opening the file in a GIS software) to find out if the vertices in a shapefile has a Z and/or an M?
danilo_fme
Forum|alt.badge.img+58
  • May 30, 2024 4:35 PM UTC
Hi @regie_alamΒ
Β
I suggest you to use the transformer to identify the coordinates x,y and z - CoordinateExtractor.
Β
And after to filter the Z values:
Β
Β
Β
Β
Β
jkr_wrk
Forum|alt.badge.img+37
  • May 30, 2024 8:21 PM UTC
Β
For measures I don't know. Still figuring out how it works.
Forum|alt.badge.img+63
Alternative approach to @danilo_fmeΒ and @jkr_wrkΒ excellent suggestions:
You can use the DimensionExtractor transformer to extract the dimension of features (either 2 or 3)Β to an attribute and then test for that. Then a MeasureExtractor can be used to extract measures. If there are no measures present it will reject those features.
jkr_wrk
  • May 31, 2024 11:21 AM UTC
I tried the MeasureExtractor and indeed it rejected my features. But didn't know if it was because it hadn't any or that I didn't search for the right name.
As for dimensions, don't want to brag, but my solution does not require extracting and removing an attribute. Someone at @redgeographicsΒ pointed me to that.
