Destination Feature Type Routing Correlator
  • Nov 7, 2024 9:51 AM UTC
  • 116 views
tono
Forum|alt.badge.img+13
When running a workspace with cache mode activated i can see in the Translation log that fme form writes ffs, and writes and index and so starts it with a process i am not familiar with: “Destination Feature Type Routing Correlator” and it takes so long to go through.
What is this process about? is it possible to avoid?
Thanks in advance!
Forum|alt.badge.img+63
You can avoid it, probably, by turning Feature Caching off.
Obviously Featur Caching is great for when you’re developing a workspace, where the added penalty of longer processing time is compensated by the ease of inspecting data at every point. However, what you can do is place a bookmark around a large portion of your workspace and then collapse the bookmark. Only the ports coming out of it will be cached, so none of the stuff that happens inside the bookmark.
