Destination Esri Shapefile Folder not found
  • Aug 20, 2024 5:10 PM UTC
  • 45 views
mushaileh
Observer
Hi all ,
i hope you can advise on this issue.
i’m using the cloud FME Flow , i uploaded my fmw file but when i run the workspace i don’t find the shape files at the Destination Esri Shapefile Folder.
any advise ?
hkingsbury
Forum|alt.badge.img+73
  • Aug 20, 2024 10:22 PM UTC
In the log, is it reading the correct location? ie where you uploaded the shapefile. If not, you’ll need to either update your process to read from that location, or expose a parameter to allow you to select the location of the shapefile.
This might be helpful - https://support.safe.com/hc/en-us/articles/25407430229645-Creating-Parameters-and-Uploading-Data-for-Self-Serve-Access
