Deleting Excel sheet given its name
  • May 21, 2019 5:15 PM UTC
  • 65 views
Is it possible to delete an entiere sheet in a Excel document? While a writer allows me to delete input in a certain sheet, I can't find a way to delete a whole sheet.
Thank you,
jovitaatsafe
Forum|alt.badge.img+11
Hi @nademmy,
If you are reading from the Excel format, you can choose in the reader parameters when you first read in your source data which sheets you want to bring in, such as in the dialog below. I have unchecked the sheet "Remove" so I will not be reading it into my workspace at all, filtering it out when I read it.
