delete a shape file after publishing it to a feature service on ArcGIS portal?
  • Apr 19, 2018 4:13 PM UTC
  • 5 replies
  • 76 views
Hi, i want to delete a shape file after publishing it to a feature service on ArcGIS portal? would appreciate if anyone could help.
So before that i have converted an excel to a shape, then a shape to a feature service but i want to delete that shape after
erik_jan
Forum|alt.badge.img+26
  • Apr 19, 2018 4:28 PM UTC
You can use the SystemCaller transformer to execute the DOS Delete statement for removing the file.
  • Apr 20, 2018 7:14 AM UTC
My first choice would be to use a FeatureWriter (rather than a regular writer) to publish to ArcGIS Portal. Then connect a SystemCaller (as suggested by @erik_jan) to the Summary port to delete the shape file.
My second choice, if you prefer keeping the regular writer, would be to delete the file in the Python shutdown script.
  • Apr 20, 2018 10:55 AM UTC
Hi @erik_jan thanks for your answer - do i need to create a new reader for the shape file i want to delete then connect the system caller? Also should the delete command in the system caller be something like this:
DELETE [D:]\\GIS\\common\\Test\\Test\\Test.gdb]DataTest_data
Sorry for all the questions I am new to fme so any help would be really appreciated.
erik_jan
  • Apr 20, 2018 1:17 PM UTC
I would use a FeatureWriter transformer to write the Shape file instead of an actual writer. That transformer has an output port (Summary) that contains an attribute with the Shape file name. (Also mentioned by @david_r)
  • Apr 20, 2018 3:50 PM UTC
Another way is, create a temporary directory with the TempPathnameCreator and write the Shapefile files there. The temporary directory created by the TempPathnameCreator and every file within it will be removed automatically by FME when the translation has completed.
