Data Inspector crashes when reading Lidar(las-files)
  • Jul 4, 2019 7:12 AM UTC
  • 69 views
klas_f
I have a workspace where I fetch las-files and clip them with a bounding box. I connected an inspector after the clip-transformer and the Inspector starts up but then crashes. The las-files are indeed created, and I can open them with i.e ArcGis Pro. I have also tried to open several of the original las-files with the Data Inspector but no success. I am using FME( 2019.0.1.0 (20190506 - Build 19253 - WIN64). I have also the 32bit-version installed(2019.0.1.0 (20190506 - Build 19253 - WIN32)) and the data inspector fails in the same way. I have run out of ideas and I hope someone can point me in the right direction. Thanks in advance.
jurgen
Forum|alt.badge.img+15
  • Jul 4, 2019 12:05 PM UTC
Maybe take a look at this post.
Seems to be the same problem with 3d data. The solution was to update the graphic drivers.
klas_f
  • Jul 4, 2019 12:24 PM UTC
Thank you! You saved the week! How could I've been so stupid that I forgot about the graphic driver. I am ashamed. Fortunately, my holiday starts the day after tomorrow and I will have time to cool down my poor brain. Thanks again!
