Custom reader: sync "SOURCE_DATASET" value with custom keyword value
  • Sep 3, 2017 7:26 PM UTC
  • 61 views
Hi all,
question please regarding "SOURCE_DATASET" value.
My custom reader has its own dataset parameter, SB_DATASET.
I need to sync SB_DATASET with SOURCE_DATASET: SOURCE_DATASET <-> SB_DATASET
The following way doesn't work:
SOURCE_SETTINGS
DEFAULT_VALUE SB_DATASET $(SB_DATASET)
GUI TEXT SB_DATASET Dataset Name:
END_SOURCE_SETTINGS
SOURCE_DATASET $(SB_DATASET)
when  IFMEReader::open(const char* datasetName,
                           const IFMEStringArray& parameters) - is called  - the datasetName is "."
The opposite doesn't work as well:
SOURCE_SETTINGS
DEFAULT_VALUE SB_DATASET $(SOURCE_DATASET)
--------OR-------->
DEFAULT_VALUE SB_DATASET $[SourceDataset]
END_SOURCE_SETTINGS
SOURCE_DATASET \"$[SourceDataset]\"
After creating the reader - SB_DATASET has "$[SourceDataset]" or empty value.
Any ideas how to sync these two variables will be very appreciated.
Thanks!
trentatsafe
Forum|alt.badge.img+7
Hello @egorbaykovnn
I will take a look at this today, and try to have a response back to you for your workday!
trentatsafe
Hello @egorbaykovnn,
Here is some preliminary information I was able to find: it appears we use a single $(Dataset) parameter to avoid the parsing situation. The GUI label that is associated with that dataset can be different based upon the format. For the SQL Server non-spatial format, the dataset parameter is similar to the database name. An example can be seen in the mssql_connection metafile, located at <FME>\\metafile\\mssql_connection.fmi.
I apologize if this doesn't really answer your question, I will do some more investigation tomorrow to try and get a concrete method/answer to you. I hope this is enough to get your started.
Here is some preliminary information I was able to find: it appears we use a single $(Dataset) parameter to avoid the parsing situation. The GUI label that is associated with that dataset can be different based upon the format. For the SQL Server non-spatial format, the dataset parameter is similar to the database name. An example can be seen in the mssql_connection metafile, located at <FME>\metafile\mssql_connection.fmi.
@trentatsafe, thanks for this info.
yeah - it doesn't help too much.
I see you are able to pass connection info to the settings dialog using
GUI NAMED_DB_CONNECTION_ENCODED NAMED_CONNECTION FAMILY:Microsoft<space>SQL<space>Server Connection
I'm not sure but this NAMED_DB_CONNECTION_ENCODED  seems to be connection specific UI. I didn't find any info about in metafile help(http://docs.safe.com/fme/html/FME_Metafiles/index.html). Based on other examples - the second parameter requires to be a connection type..just guessing.
Anyway it seems this is different then what I need.
I also tried $(Dataset) - doesn't work for me as well.
I think I could simplify my task: I need  to display the dataset value from main dialog (like "Generate workspace" dialog) into Parameters dialog.
I.e. no needs to edit the dataset on Parameters dialog; just display its actual value could be enough.
Thanks!
