Custom osm map feature config for FME server
  • Feb 26, 2019 3:06 PM UTC
  • 52 views
I have a job of transforming osm to imdf with a custom osm map feature config file. When I push this job to FME server, it seems to miss that config file and fail to run the job. How do I solve this problem? Any help?
Thank you very much.
  • Feb 26, 2019 3:11 PM UTC
Did you remember to include the config file in the publishing wizard?
  • Feb 27, 2019 2:24 AM UTC
It doesn't work, still throwing the same not fount error.
laurawatsafe
Forum|alt.badge.img+14
Hi @cezhang,
Would you be able to share a copy of the log file showing the error you are getting with this job? I'm curious about where FME Server is looking when it attempts to read that config file.
