CSS Selector
  • Aug 15, 2019 7:53 PM UTC
  • 73 views
checcosisani
Forum|alt.badge.img+14
Hi guys
i found alot of question about CSS selectorbut no answer to my case so I tried to post my question
How can select the blue info
<span>ISTITUZIONE TEMPORANEA DEL DIVIETO DI SOSTA PERMANENTE CON RIMOZIONE COATTA DEI VEICOLI IN UN TRATTO DI VIA DONATO BRAMANTE.</span>
which CSS I have to use ?
Sorry I'm new but the help need more more more examples from my point of view
thx for support
Francesco
Best answer by hollyatsafe
Hi @checcosisani,
I am no expert with CSS either however using the Reference Guide link in our Help Documentation I think setting the CSS Selector value to
.pubblicazione h2 > span
should return the required result. This will selects all the span elements where the parent is the h2 element and class=pubblicazione.
  • Aug 15, 2019 8:49 PM UTC
Hi @checcosisani,
checcosisani
  • Aug 16, 2019 3:13 PM UTC
Hi @checcosisani,
Ok
more or less it works
New challenge .. I have more than one page where the data are present so now how can iterate the request on the different pages ?
Ok
Hi @checcosisani,
My apologies I've only just seen this response. Are you using the HTTPCaller to read in your HTML? Usually you can set a limit and offset header in here to page through the results.
You can find an example workspace to demonstrate this here: https://knowledge.safe.com/questions/95898/im-working-with-an-api-but-the-results-come-back-p.html
dbaldacchino1
Thanks @hollyatsafe​ , this has helped me understand the syntax when needing to extract using multiple css selectors!
