Creator and GoogleDriveConnector Question
  • May 15, 2020
  • 12 views
At the moment, the FME script extracts a dataset from ArcOnline and creates a new document with a filename of the previously edited date. Now, I want to have the data imported into Google Drive using a GoogleDriveConnector. However, when doing so, it creates multiple copies of the same document in the drive.
Furthermore, when using a Creator instead of an excel reader, I am greeted with this line: Features not written - verify feature type fanout/dynamic settings.
I was wondeirng if anyone could help me with this issue. Thanks!
andreaatsafe
Forum|alt.badge.img+14
Hi @jimbob0513,
If I've understood correctly, you are wanting to upload the Excel file to GoogleDrive - correct?
If so, you'll want to use a FeatureWriter instead of the regular Excel writer. This will allow you to write to Excel, and then process the written data afterwards.
I would suggest reviewing this article about working with the FeatureWriter. After the FeatureWriter in your workflow you'll want to connect a GoogleDriveConnector to the Summary port, and then specify the attribute that holds the file name & location of the Excel file.
Hope this helps,
Andrea
