Creating XML for impoting Named Connections for ESRI ArcSDE Geodatabases
  • July 17, 2024
  • 19 views
mferwerda3
Forum|alt.badge.img+5
I have a lot of SDE connection files that I would like to create named connections for in FME Form 2024.
I would like if possible to automate this by creating an xml file to import.  I can use the Directory and File Pathnames Reader to get the path and the name for each sde connection file, so I am thinking I could use FME Form  to  create a xml file with all the entries I need and import that into the fme_userconnection.data filer whiteout having to do this manually one by one.
I do not need to specify anything special in the connections,  version, credentials etc. can all be defaulted, so the 2 values I need are the path and name, which I can get.
I tried making a single conn and then exporting to see the xml format, but al the values are encrypted.
Is there any kind of xml template or example xml I could use to see how to do this ?
mferwerda3
  • July 17, 2024
OK, this is simpler than I thought, it seems to be:
<named_connections>
    <database_connection>
      <keyValuesXml>
         <entry>
          <key>DATASET</key>
          <value>c:\temp\myconn.sde</value>
        </entry>
         </keyValuesXml>
      <name>test_name</name>
      <ownername>bob</ownername>
      <servicename>Esri ArcSDE Geodatabase</servicename>
    </database_connection>
  </named_connections>
