Create a database with FME?
  • Feb 27, 2019 1:18 PM UTC
  • 96 views
harmen_kampinga
Is it possible to create a PostGIS database with FME ?
  • Feb 27, 2019 1:29 PM UTC
Yes, but only manually. You can use a SQLCreator or SQLExecutor to do something like:
CREATE DATABASE my_database
  WITH OWNER = my_db_owner
       ENCODING = 'UTF8'
       TABLESPACE = my_tablespace
Then, in a second SQLExecutor, connect to my_database and execute:
CREATE EXTENSION IF NOT EXISTS postgis
  SCHEMA public
See also the docs:
https://www.postgresql.org/docs/current/sql-createdatabase.html
https://www.postgresql.org/docs/current/sql-createextension.html
nielsgerrits
Forum|alt.badge.img+67
       ENCODING = 'UTF8'
  SCHEMA public
See also the docs:
You beat me again! :p
harmen_kampinga
Thanks @david_r ! I'll give it a try
