count number of lines per file
  • May 8, 2019 1:20 PM UTC
  • 204 views
nedwaterman
Forum|alt.badge.img+9
Hello,
I need to process a number of text files holding differing numbers of data rows.
The first 7 lines are fixed - they are the loggerid / siteid / channelref / units / totals / startdate / enddate.
After that there could be a different number of rows with a datetime and a value.
I need to process these files into a sql table with the fixed 7 lines data added to the datetime and value rows. The data in the first 7 lines will change so I need FME to process the files once at a time into the writer rather than all at once.
Any idea how I do this?
Cheers
N
Best answer by erik_jan
The transformers you want to use for storing the first 7 rows of information are VariableSetter and VariableRetriever.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • May 8, 2019 2:07 PM UTC
Hope this helps.
nedwaterman
  • May 9, 2019 6:43 AM UTC
Hi erik_jan,
Thanks for your reply. I'm successfully using both those transformers but are having issues reading the data below the 7 fixed lines. I'm trying to use a Modulo counter to add line numbers to the input file, but that transformer requires an end count of rows, and I'm not sure how to calculate this. I thought a text-line count might do it, but it's not working.
Any ideas would be gratefully received!
Thanks
N
