could i get intersection between lines and points in oracle files ,spatial and not spatial
  • Mar 26, 2020 5:41 PM UTC
  • 94 views
gogopotter90
Forum|alt.badge.img+14
one of them is spatial and another oracl not spatial
just i do not want to load all oracle files in spatial and it will make the workspace slow so i was thinking to to import one spatial oracle file and another not .spatial .
is it possible to find intersection between both of them or should i load all oracle files only in spatial .Thanks
erik_jan
Forum|alt.badge.img+26
  • Mar 26, 2020 5:45 PM UTC
Both points and lines need to be spatial (having a geometry) to be intersected, using the PointonLineOverlayer.
You could use the Non Spatial reader for points if they have a X and Y attribute and then use the VertexCreator transformer to create point geometries before loading them in the PointonLineOverlayer if the table is non spatial.
Hope this helps.
gogopotter90
  • Mar 27, 2020 11:53 AM UTC
Hope this helps.
thanks,when this point is a little bit far away of lines which tolerance suggest u to have ,or could i convert the point to area because i found in lineonareaoverlayer has tolerance automatic but pointonline does not have .
just i want to find the intersection lines with point but it is far away of this point,which suggestion suggests u and thanks
erik_jan
  • Mar 27, 2020 2:10 PM UTC
I would try snapping the point to the line using the AnchoredSnapper (line as anchor), before the PointonLineOverlayer.
gogopotter90
  • Mar 28, 2020 2:37 PM UTC
Thanks alot it works great
