Copy file geodatabase to a different location with a new name.
  • Jun 18, 2026 9:26 PM UTC
  • 62 views
gneiss1.rey
Forum|alt.badge.img+5
I would like to copy an existing file geodatabase and rename it to a different location.  I have been reading up on the FILECOPY but can’t make sense of what I’ve seen.  Any help is greatly appreciated.
crutledge
Forum|alt.badge.img+55
  • Jun 18, 2026 10:42 PM UTC
Hi ​@gneiss1.rey
You may be running into trouble because a file gdb is treated as a folder. You could try and zip the fgdb and then use file copy.
Or if you are treating it as a backup before you have a workspace progress further simply use a FeatureWriter after reading in your fgdb data, write the data out as a fgdb bkp and then proceed with the next steps in your workspace.
Hope that helps!
Clifford.
gneiss1.rey
  • Jun 19, 2026 7:17 PM UTC
Thanks for the response, ​@crutledge
There must be something in the air but I am drawing a blank when compressing a file geodatabase. That seems like it might work but I can’t seem to find the transformer and parameters to do that.
Thanks in advance.
crutledge
  • Jun 19, 2026 8:29 PM UTC
Oh ​@gneiss1.rey I was thinking just change the file type extension to .zip Or...FME is pretty good at that.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/zip_files_writing.htm
Then test your file copier using the zip. Hope that helps!!
davidlee
Forum|alt.badge.img+9
  • Jun 20, 2026 6:19 AM UTC
I created a transformer called RenameFile on FME Hub, you can try it, hope that helps!
