Copy entire folder from A to B destination
  • Jan 18, 2018 4:18 PM UTC
  • 254 views
boubcher
Forum|alt.badge.img+11
I used the reader ( directory and path file name ) and writer ( file copy ) to move all file from folder A to folder B, is there a way we could move also the subfolder in A to B and keep, instead of creating a reader for each subfolder
is it possible to write it a zip file
all this is used to backup data
Thanks
erik_jan
Forum|alt.badge.img+26
  • Jan 18, 2018 4:38 PM UTC
If the destination on the File Copy Writer has an extension .zip, the writer will zip the files on the destination.
You could also use the reader to read all folders and then construct the files to copy by adding \\*.* to the folder names. This would be the source for the Copy writer. The destination would be <foldername>.zip
Hope this helps.
oscard
Forum|alt.badge.img+23
The writer has parameters to copy subfolders, too:
And to zip them, as @erik_jan has told you, just click on the yellow icon:
boubcher
  • Jan 19, 2018 10:31 AM UTC
@oscard @erik_jan
Thanks for your response, that's exactly what I did but it didn't work still taking only the file located inside the folder and no subfolder, attached the workspace filecopy.fmw,
sample
oscard
  • Jan 19, 2018 10:46 AM UTC
@oscard @erik_jan
sample
OK. Let's see.
Could you test the following changes?
- For the Reader:
- In your AttributeManager you are deleting the file extension. Try this:
@Value(path_filename)_@DateTimeFormat(@DateTimeNow(),%d %B %Y-%H h %M mn).@Value(path_extension)
