Converting points Arcmap to cells microstation V8
  • Aug 30, 2016 9:11 AM UTC
  • 5 replies
  • 78 views
Hi everybody ,
Anybody could help me ? , I'm trying to convert the points of a arcgis map to cells in microstation V8.This points are in feature class with a identificative field for register. I'm doing the next one , the input arcgis is passed for a schemaMapper and in function of the value of the identifier in arcmap I give to the ouutput in microstation this attributes : igds_cell_name , igds_type and igds_element_type , but don't transform the cells , It stay in points in ouput microstation ...
The ouput is generated with feature types by level name ....
Any help would be greater , thanks !!!
Forum|alt.badge.img+63
Did you specify a cell library (under the Parameters button when you're adding the writer, afterwards accessible through the Writer parameters in the Navigator)
itay
Forum|alt.badge.img+19
  • Aug 30, 2016 9:25 AM UTC
Yes as @redgeographics mentioned you need to specify a cell library to recreate the cells in the output format. Another option is to use the DGNStyler and specify it there.
Hi Itay and red , yes , I've specified the cell library (In option cell library file) where must found the cells to create them ...
With this attributes (igds_cell_name , igds_type and igds_element_type) and the cell library , would be enough to create the cell correctly ???
Thanks !!
Hi again , I'm trying with a DGNStyler and I can't do it , it transform the points of arcmap to points in microstation v8 (not in cells).
The cell library is defined and the cell_names exist in this ... any idea???
thank you guys , I've finished with the transformation of the cells ... finally I've used a DGNStyle and it's OK , thanks for your help ...
