Converting GEOJSON to File Geodatabase
  • Apr 30, 2018 6:56 PM UTC
  • 7 replies
  • 408 views
I am fairly new to FME and I need to convert a GEOJSON data link to a file geodatabase. I have not be able to find any help online for where to start.
Data link is here: https://data.menlopark.org/resource/vdp2-yzq3.geojson
Any help would be appreciated.
Thanks!!
danilo_fme
Forum|alt.badge.img+58
  • Apr 30, 2018 9:02 PM UTC
Hi @wjloy
You can start your Workspace with the option Generate Workspace:
File -> Generate Workspace
Please, set the configuration your Reader and Writer:
After this action, please confirm in OK button and the FME will create for you a Workspace Reader to Writer. Note that the transformer GeometryFilter will be in between the objects Reader and Writer.
Now, in the Writer - please - rename the attribute with strange character:
_@computed_region_bge3_x4j9 to for example computed
Attached the Workspace - workspacec-geojson-to-geodb.fmw
Thanks,
Danilo
  • Apr 30, 2018 9:10 PM UTC
Hi @wjloy
Thanks,
Danilo
Hi Danilo-
Thanks for the reply, this is exactly where I got hung-up and I was using the wrong writer.
I will keep you posted on my progress.
Thanks,
Whit
danilo_fme
  • May 1, 2018 1:17 AM UTC
Hi Danilo-
Thanks,
Whit
Excellent Whit. I am happy to help you
  • May 1, 2018 4:06 PM UTC
Hi @wjloy
Thanks,
Danilo
Is there a way to change the name of the output feature types from vdp2_yzq3....?
danilo_fme
  • May 1, 2018 7:38 PM UTC
Yes. You can click on icon engine in the feature type and a window will open and you rename.
  • May 1, 2018 8:07 PM UTC
Thanks, I was getting an error yesterday when I tried this same approach. I guess I was over thinking it and attribute it to user error :-/.
danilo_fme
  • May 1, 2018 10:07 PM UTC
But, its works now?
