Converting from V8 to V7 of Microstation
  • Oct 21, 2016 8:35 AM UTC
  • 270 views
Hi Everybody ,
Anybody knows what is the procedure to convert a map from V8 of microstation to V7 of microstation ???.
I have added a writer from V8 (A map that contains all the elements in V8) , and I have added a output in V7 , but I see that , If I try to configure it by geometry , doesn't appears the names of the geometry , appears Numbers , in this case , 1 for cells , 2 for lines ... etc.
The diagram executed seems to work OK , write all the features but when I open the DGN file in V7 there isn't nothing , no elements.
Any idea ??? , thanks in advanced for your help !!!
I leave the log of the translation ...
itay
Forum|alt.badge.img+19
  • Oct 21, 2016 9:08 AM UTC
Hi @xavigarciamar looks to me like you have unsupported features for v7 you are trying to write into v7.
A feature was found to have a string linkage, which is unsupported by IGDS V7 writing
2016-10-21 10:29:30| 3.9| 0.0|WARN |Rejected 939 features destined for IGDS file C:\\FME\\v8_to_v7Camp\\llavor_full_v7.dgn
Yes Itay , I have seen now , thanks for the help !! it's solved , I don't know why , but by geometry doesn't works me , if I do it by name or number it works correctly,
Thanks !!
itay
  • Oct 21, 2016 10:55 AM UTC
Thanks !!
No problem glad I could help.
