Converting a Minecraft map to a pointcloud/shapefile
  • November 29, 2015
  • 34 views
Hello,
I'm trying to convert a minecraft world to a pointcloud or a point shapefile.
I manage to convert it to a .las file but the blockID and blockData are dropped during the writing.
How can I keep these attributes?
Cheers,
Best answer by dmitribagh
When you add the LAS writer, press "Parameters" button, there is a section in the parameters called "Additional User Components". Simply type in blockID and blockData, and your LAS file will have these two components. Another possibility is to map some standard components to blockID and blockData - for example, classification and intensity. PointCloudExpressionEvaluator or PointCloudComponentCopier can this operation. You could also try using a different format, for example e57 or XYZ.
Dmitri
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
dmitribagh
Forum|alt.badge.img+17
  • November 30, 2015
Dmitri
  • December 6, 2015
Thanks it worked perfectly!
