convert json to xml
  • Feb 15, 2017 2:41 PM UTC
  • 8 replies
  • 297 views
Hello,
I execute query on my postgresdb to get result as a json: description is here http://rextester.com/ZULI42144
It looks nice but now I would like to convert it to xml. I decided to use fme to query postgres just like in example and now I have noe idea how to convert the result to xml and write it to file.
Also talking about json which I also need (I need result in JSON and XML format) what I achieved is that I simply executed postgres query end then wrote results using simple text writer so I suppose that fme doesnt really know that the query result is a JSON :)
Structure and content of the database is as described here:http://rextester.com/ZULI42144
and there is sql that is used in below sqlExecutor
This is prototype of my workspace that I have right now and the question is how to format nice xml from this list exploder (if its possible).
And here is output of the logs. Of course in the result xml I would like to have structure ike <person>...<car>...<wheel>...</wheel></car></person>
Feature Type: `Logger_LOGGED'
Attribute(64 bit integer) : `cars.carid' has value `1'
Attribute(encoded: utf-8) : `cars.comment' has value `nice car'
Attribute(encoded: utf-8) : `cars.type' has value `Toyota'
Attribute(64 bit integer) : `cars.wheels{0}.serial number' has value `11'
Attribute(encoded: utf-8) : `cars.wheels{0}.which' has value `front'
Attribute(64 bit integer) : `cars.wheels{1}.serial number' has value `12'
Attribute(encoded: utf-8) : `cars.wheels{1}.which' has value `back'
Attribute(string) : `fme_geometry' has value `fme_undefined'
Attribute(entangled: string): `fme_type' has value `fme_no_geom'
entangled to [postgres_type]
Attribute(encoded: utf-8) : `person_name' has value `Johny'
Attribute(string) : `postgres_type' has value `postgres_none'
Coordinate System: `'
Geometry Type: IFMENull
Logger: Feature is:
Attribute(64 bit integer) : `cars.carid' has value `2'
Attribute(encoded: utf-8) : `cars.type' has value `Fiat'
Attribute(64 bit integer) : `cars.wheels{0}.serial number' has value `21'
Attribute(64 bit integer) : `cars.wheels{1}.serial number' has value `22'
Attribute(encoded: utf-8) : `person_name' has value `Freddy'
Logger: Feature is:
Attribute(encoded: utf-8) : `person_name' has value `Billy'
Thanks for any hints
Best answer by takashi
Hi @witos, I would use the JSONFragmenter to fragment and flatten the JSON doc, and then use the XMLTemplater to construct an XML document.
  • JSON Attribute: persons
  • JSON Query: json["persons"][*]
  • Flatten Query Result into Attributes: Yes
  • Recursively Flatten Objects/Arrays : Yes
Here, you will have to design the destination XML schema and then set appropriate XML template expression(s) for the XMLtemplater. There is no way to generate XML schema (template) automatically from a JSON document unfortunately.
BTW, why not use the PostgreSQL XML functions? For example, execute this SQL script on an existing database with a SQLCreator,
drop table if exists wheel;
drop table if exists car;
drop table if exists person;
create table person
  id integer not null,
  name character varying(30),
  constraint person_pk primary key (id)
create table car
  type character varying(30),
  personid integer,
  constraint car_pk primary key (id)
create table wheel
  whichone character varying(30),
  serialnumber integer,
  carid integer,
  constraint "wheel_pk" primary key (id)
insert into person(id, name) values
    (1, 'Johny'),
    (2, 'Freddy'),
    (3, 'Billy');
insert into car(id, type, personid) values
    (1, 'Toyota', 1),
    (2, 'Fiat', 2);
insert into wheel(id, whichone, serialnumber, carid) values
    (1, 'front', '11', 1),
    (2, 'back', '12', 1),
    (3, 'front', '21', 2),
    (4, 'back', '22', 2),
    (5, 'front', '3', 3);
select
    xmlelement(name persons,
        xmlagg(
            xmlelement(name person,
                xmlattributes(p.id as personid),
                xmlelement(name name, p.name),
                xmlelement(name cars,
                    (select
                        xmlagg(
                            xmlelement(name car,
                                xmlattributes(c.id as carid),
                                xmlelement(name type, c.type),
                                xmlelement(name comment, 'nice car'), --constant
                                xmlelement(name wheels,
                                    (select
                                        xmlagg(
                                            xmlelement(name wheel,
                                                xmlattributes(w.id as wheelid),
                                                xmlforest(whichone, serialnumber)
                                        ) from wheel as w where w.carid = c.id
                        ) from car as c where c.personid = p.id
    ) as _xml_output
from person as p;
[Update 2017-02-17: This SELECT statement could be more efficient than the above one]
select
        xmlagg(
            xmlelement(name person, xmlattributes(p.id as personid),
                case
                    when c.cars is not null then c.cars
                    else xmlelement(name cars)
                end
    ) _xml_output
from person as p
left outer join (select
        x.personid,
            xmlagg(
                xmlelement(name car, xmlattributes(x.id as carid),
                    xmlelement(name type, x.type),
                    y.wheels
        ) as cars
    from car as x
            carid,
                xmlagg(
                    xmlelement(name wheel, xmlattributes(id as wheelid),
            ) as wheels
        from wheel group by carid) as y on y.carid = x.id
    group by personid) as c on c.personid = p.id
and then format and clean up the resulting XML document with an XMLFormatter.
Result:
<?xml version="1.0" encoding="UTF-8"?>
<persons>
<person personid="1">
<name>Johny</name>
<cars>
<car carid="1">
<type>Toyota</type>
<comment>nice car</comment>
<wheels>
<wheel wheelid="1">
<whichone>front</whichone>
<serialnumber>11</serialnumber>
</wheel>
<wheel wheelid="2">
<whichone>back</whichone>
<serialnumber>12</serialnumber>
</wheel>
</wheels>
</car>
</cars>
</person>
<person personid="2">
<name>Freddy</name>
<cars>
<car carid="2">
<type>Fiat</type>
<wheels>
<wheel wheelid="3">
<serialnumber>21</serialnumber>
</wheel>
<wheel wheelid="4">
<serialnumber>22</serialnumber>
</wheel>
</wheels>
</car>
</cars>
</person>
<person personid="3">
<name>Billy</name>
<cars/>
</person>
</persons>
Forum|alt.badge.img+63
If you use the JSON reader it will recognize objects in the JSON as such and will make it easier to write it to XML.
Alternatively, you can use a SQLCreator to pass the query directly to your database and get the result back as FME features, that way you don't have to worry about the JSON part at all.
  • Feb 15, 2017 5:08 PM UTC
I updated my question so that it may be more clear what I actually need
  • Feb 16, 2017 5:55 AM UTC
create table person
create table car
  personid integer,
create table wheel
  carid integer,
    (1, 'Johny'),
    (2, 'Freddy'),
    (3, 'Billy');
    (1, 'Toyota', 1),
    (2, 'Fiat', 2);
select
        xmlagg(
                    (select
                        xmlagg(
                                    (select
                                        xmlagg(
    ) as _xml_output
from person as p;
select
        xmlagg(
                case
                end
    ) _xml_output
from person as p
        x.personid,
            xmlagg(
                    y.wheels
        ) as cars
    from car as x
            carid,
                xmlagg(
            ) as wheels
Result:
<persons>
<name>Johny</name>
<cars>
<car carid="1">
<type>Toyota</type>
<wheels>
<wheel wheelid="1">
</wheel>
<wheel wheelid="2">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Freddy</name>
<cars>
<car carid="2">
<type>Fiat</type>
<wheels>
<wheel wheelid="3">
</wheel>
<wheel wheelid="4">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Billy</name>
<cars/>
</person>
</persons>
  • Feb 16, 2017 7:32 AM UTC
create table person
create table car
  personid integer,
create table wheel
  carid integer,
    (1, 'Johny'),
    (2, 'Freddy'),
    (3, 'Billy');
    (1, 'Toyota', 1),
    (2, 'Fiat', 2);
select
        xmlagg(
                    (select
                        xmlagg(
                                    (select
                                        xmlagg(
    ) as _xml_output
from person as p;
select
        xmlagg(
                case
                end
    ) _xml_output
from person as p
        x.personid,
            xmlagg(
                    y.wheels
        ) as cars
    from car as x
            carid,
                xmlagg(
            ) as wheels
Result:
<persons>
<name>Johny</name>
<cars>
<car carid="1">
<type>Toyota</type>
<wheels>
<wheel wheelid="1">
</wheel>
<wheel wheelid="2">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Freddy</name>
<cars>
<car carid="2">
<type>Fiat</type>
<wheels>
<wheel wheelid="3">
</wheel>
<wheel wheelid="4">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Billy</name>
<cars/>
</person>
</persons>
Thanks for this great explanation. I completely focused on solution with fme json to xml conversion that I forgot about built in xml features in postgres.
  • Feb 16, 2017 11:54 AM UTC
create table person
create table car
  personid integer,
create table wheel
  carid integer,
    (1, 'Johny'),
    (2, 'Freddy'),
    (3, 'Billy');
    (1, 'Toyota', 1),
    (2, 'Fiat', 2);
select
        xmlagg(
                    (select
                        xmlagg(
                                    (select
                                        xmlagg(
    ) as _xml_output
from person as p;
select
        xmlagg(
                case
                end
    ) _xml_output
from person as p
        x.personid,
            xmlagg(
                    y.wheels
        ) as cars
    from car as x
            carid,
                xmlagg(
            ) as wheels
Result:
<persons>
<name>Johny</name>
<cars>
<car carid="1">
<type>Toyota</type>
<wheels>
<wheel wheelid="1">
</wheel>
<wheel wheelid="2">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Freddy</name>
<cars>
<car carid="2">
<type>Fiat</type>
<wheels>
<wheel wheelid="3">
</wheel>
<wheel wheelid="4">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Billy</name>
<cars/>
</person>
</persons>
As my own exercises, I tested conversion from JSON to XML using the XMLTemplater.
Basic
XMLTemplater_1: ROOT Expression
<person>
    <name>{fme:get-attribute("person_name")}</name>
    if (fme:has-attribute("cars.carid"))
    then
        <cars>
            <car carid="{fme:get-attribute("cars.carid")}">
                <type>{fme:get-attribute("cars.type")}</type>
                <comment>{fme:get-attribute("cars.comment")}</comment>
                <wheels>{fme:process-features("SUB")}</wheels>
            </car>
        </cars>
    else
        <cars/>
</person>
XMLTemplater_1: SUB Expression
<wheel>
    <which>{fme:get-attribute("which")}</which>
    <serialNumber>{fme:get-attribute("serial number")}</serialNumber>
</wheel>
XMLTemplater_2: ROOT Expression
<persons>{fme:process-features("SUB")}</persons>
XMLTemplater_2: SUB Expression
{fme:get-xml-attribute("_result")}
  • Feb 16, 2017 11:55 AM UTC
create table person
create table car
  personid integer,
create table wheel
  carid integer,
    (1, 'Johny'),
    (2, 'Freddy'),
    (3, 'Billy');
    (1, 'Toyota', 1),
    (2, 'Fiat', 2);
select
        xmlagg(
                    (select
                        xmlagg(
                                    (select
                                        xmlagg(
    ) as _xml_output
from person as p;
select
        xmlagg(
                case
                end
    ) _xml_output
from person as p
        x.personid,
            xmlagg(
                    y.wheels
        ) as cars
    from car as x
            carid,
                xmlagg(
            ) as wheels
Result:
<persons>
<name>Johny</name>
<cars>
<car carid="1">
<type>Toyota</type>
<wheels>
<wheel wheelid="1">
</wheel>
<wheel wheelid="2">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Freddy</name>
<cars>
<car carid="2">
<type>Fiat</type>
<wheels>
<wheel wheelid="3">
</wheel>
<wheel wheelid="4">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Billy</name>
<cars/>
</person>
</persons>
Advanced
XMLTemplater: ROOT Expression
XMLTemplater: SUB Expression
<person>
    then
        <cars>
                <wheels>
            for $i in (0 to xs:integer(fme:get-attribute("_element_count"))-1)
            let $w := fme:get-attribute(fn:concat("cars.wheels{", $i, "}.which"))
            let $s := fme:get-attribute(fn:concat("cars.wheels{", $i, "}.serial number"))
            return <wheel>
                       <which>{$w}</which>
                       <serialNumber>{$s}</serialNumber>
                   </wheel>
                </wheels>
            </car>
        </cars>
    else
        <cars />
</person>
  • Feb 16, 2017 3:16 PM UTC
create table person
create table car
  personid integer,
create table wheel
  carid integer,
    (1, 'Johny'),
    (2, 'Freddy'),
    (3, 'Billy');
    (1, 'Toyota', 1),
    (2, 'Fiat', 2);
select
        xmlagg(
                    (select
                        xmlagg(
                                    (select
                                        xmlagg(
    ) as _xml_output
from person as p;
select
        xmlagg(
                case
                end
    ) _xml_output
from person as p
        x.personid,
            xmlagg(
                    y.wheels
        ) as cars
    from car as x
            carid,
                xmlagg(
            ) as wheels
Result:
<persons>
<name>Johny</name>
<cars>
<car carid="1">
<type>Toyota</type>
<wheels>
<wheel wheelid="1">
</wheel>
<wheel wheelid="2">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Freddy</name>
<cars>
<car carid="2">
<type>Fiat</type>
<wheels>
<wheel wheelid="3">
</wheel>
<wheel wheelid="4">
</wheel>
</wheels>
</car>
</cars>
</person>
<name>Billy</name>
<cars/>
</person>
</persons>
I tried to generate xml directly from sql query but it takes like 1k times longer then generating JSON. Did you know about this performance issue regarding xmlelement and xmlagg compared to json_build_object?
  • Feb 17, 2017 1:42 AM UTC
I don't know exact reason why the SQL query with XML functions took longer time than the query with JSON functions, but the SQL statement with XML functions has nested SELECT statement, so the number of sub query executions could be very large if the number of "person" records was large. I think it's one of possible reasons.
If so, this statement may be better than the previous one.
[Moved 2017-02-17: See the update in my first post]
