Convert JP2 to ECW and create TAB file as well.
  • Feb 20, 2022 10:56 PM UTC
  • 220 views
I use to run the conversion process of GeoTiff to ECW with compression of 90 and generate TAB file using FME2020, i never experienced any issue.
I recently upgraded FME to 2021.2, I have to convert JP2 to ECW with compression of 90 and want TAB file as well.
I ran the process multiple time, but I don't get TAB file generated in output folder.
Even I found new attribute in this FME version, where it asks to select ECW Format version (2 or 3), which one to select..?
Best answer by rapidmapper
Hello, Thank you for your response. I have writer settings pretty much same as in your screenshot..
ECW-writer-settingsecw-writer-settings2
I got it what was the issue, I was using Trial version which has a limitation to transform ECW and generate TAB file.
Once I tried same process on my licensed FME machine,it works..
Not documented anywhere, lesson learnt hard way.
Forum|alt.badge.img+63
Do you have the paramter "Tab File Generation" set on the ECW writer feature type?
Screenshot 2022-02-21 at 09.58.19As for the version, generally speaking it would be best to pick the latest version unless you have a very good reason not to do so (such as the application you want to use the ECW in not supporting that new version). So it's really up to you.
Does the JP2 file that you're reading have a coordinate system set?
  • Feb 23, 2022 1:03 AM UTC
