Convert decimal coordinates to DMS format with hemisphere (E / N)
  • Mar 10, 2026 7:53 AM UTC
  • 63 views
fakimochere
Forum|alt.badge.img+3
Hello,
I am trying to convert decimal coordinates into a DMS format with hemisphere indication.
Example:
Decimal format:
1.4861803 ; 43.5713123
Target format:
1°29'10.2491" E ; 43°34'16.7243" N
In my workflow, I used the DMSCalculator transformer to split the coordinates into degrees, minutes and seconds. This part works correctly.
However, I am now stuck when trying to reconstruct the final formatted string. I am not sure what is the best way to:
  • concatenate degrees, minutes and seconds into a single formatted value
  • add the correct hemisphere suffix (E/W for longitude and N/S for latitude)
My goal is to automatically produce a final attribute formatted like:
1°29'10.2491" E
and
43°34'16.7243" N
Does anyone know the best approach in FME to rebuild this format after using the DMSCalculator?
Thanks in advance for your help.
geomancer
Forum|alt.badge.img+71
  • Mar 10, 2026 3:27 PM UTC
Same question, same user, with response can be found here:
