Conversion of a shape to kml file.The issue is to sort by month and not by alphabetic or numeric way
  • Jul 19, 2013 10:02 AM UTC
  • 86 views
attribute value of a field in a specific order of my attribute
I have an issue as I would like to sort my output kml file in a hierarchical way. I have for the moment sort by country (alphabetic, 1order), by year(numeric,2 order) and I would like to sort now by month but not in an alphabetical way, but from jan, feb, mar...... That means in a monthly order. I have got the value in a field of my shapefile, but I do not know how to display it correctly by month.
Does anybody know the way to do it ?
Thanks in advance!
Arnaud
Best answer by ebygomm
Use an attributevaluemapper to assign a number to a month
so
Jan = 1
Feb  = 2
Mar = 3 etc. and then sort by this new attribute
Forum|alt.badge.img+54
  • Jul 19, 2013 10:10 AM UTC
so
Jan = 1
Feb  = 2
  • Jul 23, 2013 7:46 AM UTC
Thank you for your answer.
I tried to add attributevaluemapper on my long process but it did not work. Maybe I did not add the right parameters or I did not add this attributevaluemapper at the right place. Could you tell me if there some parameters to add?
Thanks,
Arnaud
  • Jul 24, 2013 1:55 PM UTC
After many many tries it works. Thanks for your solution!
