constructor IligmlWriter(OutputStream, TransferDescription) is undefined?
  • Nov 27, 2015 8:58 AM UTC
  • 32 views
Using FME Server together with FME 2013 Entines (Build 13547) I obtain the below error message:
2015-11-26 14:41:42| 89.0| 0.0|ERROR |java.lang.Error: Unresolved compilation problem: The constructor IligmlWriter(OutputStream, TransferDescription) is undefined
I have no Idea at all what goes wrong. Any hints?
mark2atsafe
Forum|alt.badge.img+59
Hi. I've searched through our databases and other sources of information. It appears to be a GML writing problem but I don't see any issues that were fixed since 2013 that might solve that problem.
Have you tried running the same workspace on FME Desktop? Does it work there? Does it even have a GML-based Writer in the workspace? If so, which format? Just trying to get a feel for whether it's a Server issue or a problem with the workspace/data itself.
Either way it's an error that shouldn't occur and I think it's probably best if you contact our support team (safe.com/support) and ask them to investigate.
