Connecting to MongoDB Atlas DBaaS
  • May 11, 2017 2:50 AM UTC
  • 73 views
darkspatiallord
Forum|alt.badge.img+8
Hi
Getting the following Tunnel error - reading online seems it might be an SSL issue - Can this be looked at in the Database connection parameters and the reader and writer for MongoDB
Seems only to be an issue if using the hosted service
MONGODB writer: Cannot connect: DBClientBase::findN: transport error: mydatabase-shard-00-00-ch90m.mongodb.net:27017 ns: admin.$cmd query: { ismaster: 1 } MONGODB writer: Unable to locate or open database 'mydatabase-shard-00-00-ch90m.mongodb.net'. Please ensure the database exists and is accessible. Note that the MONGODB writer does not have the ability to create a new database. However, creating the database manually in advance allows for subsequent data insertion
Best answer by trentatsafe
Hello @darkspatiallord,
MongoDB Atlas is supported in FME 2019.1 and will be officially released in July.
Beta's are currently available here: https://www.safe.com/support/support-resources/fme-downloads/beta/
did you find an answer for this issue? Facing the same..
Thanks.
Vincent.
Hello,
I have the same issue here. Is there a solution after all???
Thanks.
Stratos
trentatsafe
Forum|alt.badge.img+7
  • Feb 19, 2019 8:02 PM UTC
