Compress delta tables in ArcSDE Enterprise geodatabase using FME?
  • Nov 5, 2020 5:23 PM UTC
  • 0 replies
  • 49 views
Hello all,
I'm wondering if anyone has any suggestions for using FME to compress the delta tables of an ArcSDE enterprise geodatabase? I'm thinking it could be achieved using the python caller to run the ArcPy command for executing the compression. Does anyone have and suggestions or best practices in this area? Thanks!
