Comparing two excel tables and find the gaps between them;
  • Jul 20, 2015 10:37 PM UTC
  • 55 views
lubna_najeh
Hi All,
I have 2 table and I want to find the gap between them and join them in one table to better comparison and presentation of gaps
Can I do this comparision using FME?
Thank you,
Lubna
Best answer by pratap
Yes, with the help of Feature Merger Transformer.
Merged, Not Merged and Unreferenced ports have to considered for the output.
I have observed that Headers are changed in Output. V1 which is Numerical in input have changed to Alphabets. If it is required then additional attribute creator is requird to change the header.
Pratap
pratap
Forum|alt.badge.img+12
  • Jul 21, 2015 5:32 AM UTC
Pratap
I'm no't sure, but maybe, a ChangeDetector could be a option. You can create features per each table and use them as inputs int he transformer.
pratap
  • Jul 24, 2015 4:36 AM UTC
Is it not solved with my previous suggestion above???
lubna_najeh
  • Jul 26, 2015 5:44 AM UTC
Hi All,
It works with me thank you Pratap
I will try the second option :)
Lubna
