Colour conversion from PDF to tiff
  • May 5, 2020 2:27 PM UTC
  • 5 replies
  • 238 views
disco2000
Forum|alt.badge.img+3
I have a PDF-map (image without marginalia) generated from ArcGIS Pro that I want to convert to a GeoTIFF (8-bit palette) and use as raster data. The colours look fine in the PDF but somehow come out alot darker when i convert them to GeoTIFF. This happens if I export as an RGB as well... Is there a colour handling property that I have overlooked or is this a common issue between ESRI and FME in their PDF reader/writer?
Source PDF
Output GeoTIFF
Best answer by disco2000
It looks like the color management properties in ArcGIS Pro was the culprit. I changed the "Color conversion rule" (under project settings) to "preserve color values" and everything turned out fine.
Good to know!
Forum|alt.badge.img+63
It could be that the original PDF (or rather the raster that's in there) is using indexed colors rather than RGB, I don't have a copy of FME handy at the moment so I can't try this out, but if memory serves me well the RasterPaletteResolver is the one to try.
mark2atsafe
Forum|alt.badge.img+59
Has the PDF image got an alpha channel that the GeoTIFF doesn't? Unlikely, but if the entire map is consistently darker, then it's possible.
disco2000
  • May 6, 2020 6:00 AM UTC
The PDF does have an alpha channel, I removed it but same problem. Apparently the PDF has a color space that isn't standard, which could be the cause...
disco2000
  • May 6, 2020 6:03 AM UTC
Good thought, but the PDF is a four channel RGBA.
disco2000
  • May 6, 2020 7:46 AM UTC
Good to know!
