CityGML - extract footprint and building id
  • Dec 4, 2015 11:27 AM UTC
  • 5 replies
  • 269 views
I have got citygml files. I need to extract the footprint of each building and the corresponding building id, such as:
<bldg:Building gml:id="_26991">
One building can have more than one footprint.
I'm not very familiar with citygml / fme. Can someone give me a hint how to extract the footprints (which seems quite easy) but additionaly get the building id as well. It seems I need to access the "building" for the id and "footprint" for the footprint. But how do I get building - id for each footprint?
Many Thanks, Rob
Forum|alt.badge.img+5
  • Dec 4, 2015 11:36 AM UTC
Hey Rob,
It's been a while since I dove headfirst into CityGML. Any chance you could include a small example data file?
Forum|alt.badge.img+63
Have you tried the CityGML reader that ships with FME? That should (assuming the CityGML data is structured properly) do a good job of extracting the information you need.
  • Dec 4, 2015 2:51 PM UTC
Hi Kim,
I have attached a file:
ctemp3d-stadtmodell1052-43-3.zip
I looked at the file and it seems all buildings are part of a
<cityObjectMember>
In some cases the <cityObjectMember> contains <groupMember> which then contains the <building>. The ID I'm after is then attached to <cityObjectMember>.
In other cases the <cityObjectMember> contains one <building> and the ID in question is attached to <building>.
Many thanks in advance for any suggestion,
Rob
  • Dec 7, 2015 12:22 PM UTC
Thanks for posting the file @rob_f, always makes it easier.
The post of @redgeographics is right in suggesting the CityGML reader, I hope you were using that one already.
If you add a CityGML reader it will ask which featuretypes you want to include. Am I correct in assuming you want the GroundSurface feature? Your example file has 155 of them. Each of these has a gml_parent_id attribute:
  • If it doesn't start with fme_gen it seems to be the id of the building, which is what you wanted.
  • If it starts with fme_gen the parent had no gml_id and FME added one. This seems to indicate the parent is a building without a gml_id. In this case you want the id of its parent groupmember.
I would suggest you also include the Building feature type when adding the reader. You can then test out the cases mentioned above. For the ones that have a made up id, use a FeatureMerger to join the GroundSurface with the Building (building.gml_id = groundsurface.gml_parent_id). The gml_parent_id of the Building is the one you want. Otherwise, just get the gml_parent_id of the GroundSurface.
Hope this helps!
hth
Participant
  • Participant
  • Feb 29, 2016 3:29 PM UTC
Hi rob_f,
you can add a citygml-importer. Be sure you use the workflow-option "individual featuretypes". That should help you to only read the groundsurfaces and buildings. The groundsurface is your footprint. Use the tester on the groundsurfaces for gml_parent_ID (search for containing string "fme-gen-") failed => gml_parent_id is your id. Passed => use the featuremerger to merge groundsurface (gml_parent_id) with building (gml_id), with that you'll get the rest of the IDs attached to your groundsurfaces.
