CenterlineReplacer Error
  • June 4, 2014
  • 196 views
I am having a bit of a frustrating experience with the CenterlineReplacer that I am hoping someone can help with.
Desired Outcome:
Centerline the entire length of the polygon "tiles." The length is a user-parameter and will determin the length of the line. By having the centerline "clipped" inside the polygon I am losing the correct length.
Background:
I have a number of 'tiles' (ie polygons) that I want to essentially spit in half and keep the centerline. Sounds like a job for the CenterlineReplacer.
However, whenever I run the transformer I get 3 undesirable results.
  • First, it does not split the entire lengh. It essentially starts partway down the middle.
  • Second, one of the centerlines always "snaps" to the corner of one polygon.
  • Third, the line directions vary. I would like all line directions in the same orientation. Note, I have a process that fixes this but it's more of a hack.
Here is a screenshot of the undesireable output:
Does anyone have any better ideas/suggestions on how to split each polygon 100% down the middle? Again, the final output is the centerline itself.
Regards,
Matthew Brucker
Best answer by takashi
Hi Matthew,
If every polygon is always a rectangle (having just 4 edges), a possible way is as the following. Assuming every rectangular polygon has unique ID as its attribute:
1) Chopper: Decompose every rectangle into their edge lines.
Mode: By Vertex
Maximum Vertices: 2
2) LengthCalculator: Calculate the length of every edge.
3) Sorter: Sort the edges  by ID and length ascending.
4) Sampler: Select first 2 edges (i.e. shorter edges of rectangle) for each ID.
Group By: ID
Sampling Type: First N Features
Sampling Amount: 2
5) CenterPointReplacer: Transform selected edges into their center points.
6) PointConnector: Connect each 2 points to create required lines.
Connection Break Attributes: ID
Be aware that  this way may not work when a polygon is not clean (e.g. having duplicate vertices etc.). In such a case, consider cleaning up polygons before the processing.
Another approach. If input polygons are clean rectangles, this way may also work.
1) CenterLineReplacer: Create shorter center lines (Mode: Medial Axis).
2) Deaggregator: De-aggregate the line, since the CenterLineReplacer always creates aggregate feature.
3) Extender: Stretch the lines.
4) Clipper: Clip stretched lines by the original rectangles (Group By: ID).
Result:
Takashi
  • June 5, 2014
Hi Matthew,
Mode: By Vertex
Maximum Vertices: 2
Group By: ID
Sampling Amount: 2
Result:
Takashi
Hey Takashi,
The second approach is basically what I did/am doing. I find that with FME I usually come up with some pretty elegant solutions. At this point I have a viable solution so I'm not going to push this one too much.
I did struggle with the aggregate portion of the CenterLineReplacer for a week before I stumbled on that. I wish that was a little better documented but FME is like the wild west of GIS!
