Cannot update SDE and featuremerger doesn't join correctly
  • May 2, 2018 2:47 PM UTC
  • 64 views
I need to update an arcmap sde feature but just one column. I use feature merger to join the data I am planning to use to update the SDE. However, I have found featuremerger to be really hit and miss, often it won't join all the features that should be.
The main issue I am having is after feature merger there are 17 features that are joined. I then want to update my SDE (which was also the input) based on the join. It runs successfully but won't update my fields.
The workflow looks like this
Reader A
Reader B featuremerger Attribute manager Writer
I need an attribute from reader b to update the writer which is the same feature as reader A
erik_jan
Forum|alt.badge.img+26
  • May 2, 2018 3:44 PM UTC
About the FeatureMerger, It will (with default settings) not add attributes from B on A if that attribute already exists on A.
You can use the attribute settings to either tell it to use the Supplier attributes when conflicting or add a prefix to the supplier attributes. That allows you to use the supplier attributes for the update. (see doc section on Attribute Accumulation)
fmelizard
Forum|alt.badge.img+22
  • May 2, 2018 5:24 PM UTC
Hi @sylvia81, what have you set on the Writer for updates?
  • May 3, 2018 11:51 PM UTC
sorry - I forgot to add I have set the feature merger to supplier attributes only. I'm only trying to add one field from the supplier anyway to my feature
  • May 4, 2018 12:42 AM UTC
I have tried to use the field I need updating as the key ID
