Can I use attributes from a shape file grid to name my raster writer output files?
  • Mar 23, 2017 2:27 PM UTC
  • 109 views
Hi All,
I need to automate the process of cutting up an image file into approximately into 11,500 separate images.
I have my image file. I have my grid shape file that contains attributes that I want to use as my output image file names.
I can get image outputs using clipper that are exactly as I expect (correct dimensions etc) but cannot figure out how to name them correctly.
I'm convinced that I'm missing something quite simple here.
I have been searching through the knowledge center but can't find exactly what I'm looking for.
Has anyone had experience with this?
I'm using FME Desktop 2015
Best answer by erik_jan
The Clipper transformer will clip the raster and allows to add the attribute from the grid on the output.
See the settings in this image:
Next use the attribute on the Writer Fanout to create a file with the right name (look in the Navigator window for Dataset Fanout.
erik_jan
Forum|alt.badge.img+26
  • Mar 23, 2017 2:30 PM UTC
Hi eric_jan, just got into work and tried out the solution you posted. It works great!!!
Thank you for your help
