Can I start a reader with a choice of 2 input files location?
tschoppenhof
Forum|alt.badge.img+7
As an additional source for a transformation I need an xml-File with a given name. This file can be located online (url-adress). If its not online the XML-Reader should use a local file (with the same name). How can I implement this in a Workspace?
Thanks for your help
erik_jan
Forum|alt.badge.img+18
  • February 15, 2019
You could use the FeatureReader instead of the XML reader.
That way you have an option to manipulate the file name before getting to that transformer.
You could use the FileExistenceChecker (a tranformer available on the FME Hub) to see if the XML file is available online.
Hope this helps.
tschoppenhof
  • February 18, 2019
Hope this helps.
I tried the FileExistenceChecker but it seems that it can not check url adresses. I didn't recognize an url-Adress that the xml-Reader is able to read. Any Idea what the problem could be? Test_FEC.fmw
Forum|alt.badge.img+39
  • February 18, 2019
Why not just use a http caller to check for the existence of the file?
nielsgerrits
Forum|alt.badge.img+54
Or use the HttpCaller to hit the XML adres. If Rejected then initiate a FeatureReader with the local file.
dynamicreadsample.fmwt
tschoppenhof
  • February 18, 2019
Your Input helped a lot, thank you very much.
