Calculate NDVIRe
  • Jul 20, 2024 10:46 PM UTC
  • 89 views
mr_fme
Forum|alt.badge.img+9
How can I calculate NDVIRe, using RasterExpressionEvaluator?
  • NDVIRe=Band 8 (NIR)+Band 5 (Red Edge 1) / Band 8 (NIR)−Band 5 (Red Edge 1)​
I don´t know to configure the transformer properly…
Thank´s
Best answer by dmitribagh
Good!
But the NDVIre is another index.
It is not the same as NDVI.
I need to create the calculation.
Hi @mr_fme
the types of bands do not matter. All that matters is that you need two bands and some math with it. You can use NDVICalculator directly if you send IR to Infrared port, and Red Edge - to Red. Or, you can open the transformer and copy the expression from RasterExpressionEvaluator_2 - this is the transformer that does the actual calculation. Red goes to A input port, Infrared goes to B.
Dmitri
hkingsbury
Forum|alt.badge.img+73
  • Jul 21, 2024 9:44 PM UTC
mr_fme
  • Jul 22, 2024 1:04 AM UTC
Good!
dmitribagh
Forum|alt.badge.img+20
  • Jul 22, 2024 6:16 AM UTC
Good!
Hi @mr_fme
Dmitri
mr_fme
  • Jul 22, 2024 2:09 PM UTC
Thanks
