Thanks, @max_h , for your response. I am currently working through these tutorials to build my understanding. If you or anyone else in this community have any sample CAD files for water and wastewater as-built drawings, I would greatly appreciate having a look at them as well.
AutoCAD DWG Block Attribute Extraction — hydrants/valves/manholes in these utility files are typically blocks with attribute tags, and this shows how to pull those out (includes its own sample DWG for practice)
Working with AutoCAD Layouts — useful once you’re ready to look at paper space/viewports rather than just model space geometry
Hope this helps!
Thanks @veronikaatsafe … I will look through this CAD files
Thank you for providing publicly accessible municipal files and the basic FME tutorials for CAD files. I am now exploring how FME can be used to perform the following checks on CAD files before they are loaded into ArcGIS:
Check whether all mandatory attributes have been entered and identify any missing attributes.
Link CAD files with the Excel template using a unique ID, allowing attributes from both files to be combined and validated.
Verify that assets in the as-built CAD drawings have the correct connectivity. For example: Water lateral pipes are correctly connected to water main pipes. Water meters are correctly connected to manifolds. Other network assets are connected as intended.
Check whether the received CAD files meet the required data and drafting standards.
Is there an example FME workflow available that demonstrates how to perform any of the checks listed above?
Any guidance, sample workspaces, or references from this group would be greatly appreciated.
