Bounding volume of Tiles in Cesium 3D Tiles
  • Jan 30, 2018 3:35 PM UTC
  • 184 views
Hi All,
I am trying to convert ERSI shapefile(LOD0) to Cesium 3D Tiles using FME 2017 Writer. Here is my workspace :
When i use Cesium to visualize it, bounding volume of tile is skew like this:
I use Cesium's Template code to visualize(change url to my tileset path) so i guess my code is fine.
Could anyone help me on this?
Thank you,
  • Jan 31, 2018 2:10 AM UTC
Hi @chuthuavu1996, are the 3D objects (looks like buildings) displayed on the correct location with correct sizes?
Hi @takashi,
My 3D building location and sizes displayed correctly. I do not have height data of 3D object so i fake it in my FME workspace. You can check my shapefile: hanoishp.zip
  • Dec 13, 2018 4:07 PM UTC
Hi, @chuthuavu1996. I have a similar problem with boundingbox converting collada to 3d tiles. Did you have a chance to find the solution for it?
  • Nov 9, 2021 1:01 AM UTC
I am also facing a similar issue when using FME Workbench 2021.1.2 . Hope that issue can be resolved! If using Sphere as bounding volume looks good for you. Please consider to update your tileset.json to resolve this issue temporarily
