Best option for catching DB related errors when writing to Oracle spatial tables
  • Oct 4, 2020 11:25 PM UTC
  • 68 views
dms2
Forum|alt.badge.img+11
My translation writes features to spatial and non spatial Oracle tables in a given order.
The problem is that any eventual DB related error should be reported to a web service and also logged to an xls file.
I'm using Featurewriters to control the writing order ​but the Featurewriter transformer has no Rejected port. How do I catch DB errors then?
SQLExecutor is fine for non spatial tables but not for spatial tables with complex geometries (due to the character number limitation for sql statements).​
Should I keep the Featurewriter approach and use a shutdown python script to catch DB errors and do the Excel and web service part​? Is there any other option?
Thanks for the help.​
  • Oct 5, 2020 7:17 AM UTC
Unfortunately this is a known weakness with the FeatureWriter, please consider adding your vote here: https://community.safe.com/s/idea/0874Q000000TkwiQAC
I would've used FeatureWriter + Python for this. You could also consider wrapping your workspace into a second (master) workspace, in which you could e.g. analyze the logs messages output from the FeatureWriter.
dms2
  • Oct 5, 2020 7:28 AM UTC
I'm voting right away.​
Thanks!​
