Basics.... writing text file
  • Aug 4, 2017 2:46 PM UTC
  • 1009 views
harmen_kampinga
Hello,
In the Text_File writer I cannot select an attribute I've just created
How can I solve that?
Best,
Harmen
Best answer by david_r
The text file writer only has one attribute "text_line_data", you cannot add others.
For each feature sent to the writer, the value of "text_line_data" will be output on a separate line, all other attributes are ignored.
  • Aug 4, 2017 2:54 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Aug 4, 2017 2:56 PM UTC
Hi Harmen,
Would the AttributeFileWriter be a solution for what you need?
Erik Jan
harmen_kampinga
@david_r
Adding my data to the "text_line_data" attribute did the trick ;-)
@erik_jan
The AttributeFileWriter doesn't do what I expected it to do...
