Background map on a pdf
In this webinar (https://www.safe.com/webinars/best-in-show-fme-tips-tricks-for-productivity/) was a section titled 'How to get a background map on a PDF'. This is exactly what I want to do however my organization is only at FME 2020.2. So the Reader format of OGC WMTS is not available to me. Any suggestions on how to do this in FME 2020?
Forum|alt.badge.img+58
If there is a WMS available for that map you can use that instead (with the WMS reader of course)
I ended up publishing the basemap as a map service, then used the export off that service. I followed Nielsgerrits answer that he posted to this question
https://community.safe.com/s/question/0D54Q00008BzQlQSAV/how-to-pull-a-raster-from-an-esri-basemap-httpsservicesarcgisonlinecomarcgisrestservicesworldtopomap-to-use-within-fme-workbench
