AutoCAD2004Writer::setExtents
  • Apr 25, 2017 4:13 PM UTC
  • 0 replies
  • 122 views
I'm trying to create an error file with AutoCAD DWG/DXF Reader/Writer and i've got an issue :
Specified block 'CENTRO_LOCAL' is not defined in AutoCAD file. Skipping feature
MULTI_WRITER: multi_writer_id `3': Writing feature 0
AutoCAD Writer: Performing database audit...
AutoCAD Writer: An error occurred for dataset 'D:\\Routines2014\\LOGS\\DWG_ENGLOS_01122016.dwg', in function AutoCAD2004Writer::setExtents. Exception thrown: 'Invalid input'
... Last line repeated 2 times ...
Anybody's got an idea ?
