AUTOCAD WRITER Unused Objects
  • May 6, 2020 9:29 AM UTC
  • 0 replies
  • 34 views
franco69
Forum|alt.badge.img+11
Hi there Guys,
i had a topic about few days ago.....
i have an autocad file where i want to write not all layers from the template (only the layers which comes with an feature type in the reader).....tha i solved with help from you with the parameter: PURGE UNUSED OBJECTS
So now i have following problem with one layer:
layer 0 has a block included which i have to explode and also use block feature type for components i have set on YES
this block has include some layers i dont want to write (because of purge unused.....)
but they be written. (maybe because they are originally included in a layer which has a feature type?)
how can i explode the block, take the original layer definitions with me and filter the not used layers (parameter?)
I've tried also the REAL DWG Writer
Thanx and Greetz
Franco
