AutoCAD Version
pratap
Forum|alt.badge.img+11
Is there any possibility to know the version of AutoCAD dwg file in which it is saved-in...
Prtap
itay
Forum|alt.badge.img+17
  • April 28, 2017
You can if you apply the method described here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-find-which-version-of-AutoCAD-was-used-to-create-save-a-DWG.html
by reading it as a text file and mapping the version values into the correct dwg version.
Just make sure you use the schema attributes in the text reader to have the original dwg name.
Hoe this helps.
pratap
  • April 28, 2017
Thanks alot... Nice trick
itay
  • April 28, 2017
Glad I could help.
larsatomkeere
Forum|alt.badge.img+8
When you add the dwg-file as a reader, the version is stated in the log:
AutoCAD Reader: Successfully opened the 'Release2010' AutoCAD file
gabriel_hirsch
Forum|alt.badge.img+12
A less known but very useful parameter when reading DWG files is "Read Drawing System Variables":
Then you get an null feature called autocad_info which holds many useful attributes, like DWG version.
See documentation here (only available from FME 2018): http://docs.safe.com/fme/2018.0/html/FME_Desktop_Documentation/FME_ReadersWriters/acad/Drawing-System-Variables.htm
