Autocad to NOSQL
  • May 3, 2019 2:21 PM UTC
  • 66 views
We are currently using AutoCAD Map 3D and use Oracle spatial database for storing spatial data. We are going through FME software like to know :
1. Can FME support moving DWG to NOSQL database (like MongoDB support ) ?
2. For Oracle spatial can FME handle and save blocks as well ?
chrisatsafe
Hi @srilakshmibodir,
FME has lots of support for NoSQL databases, like MongoDB, Apache CouchDB, Amazon DynamoDB and Google Big Query; however, some only support reading or are non-spatial formats. You can check out the full list of supported formats here: https://www.safe.com/fme/formats-matrix/#!
MongoDB, has vector geometry support and both a reader and a writer - if you want to look more into the reader/writer spec, you can find a full list of supported attribute/geometry types and more in the Mongo DB Documentation.
As for blocks, FME certainly handle blocks (both reading and writing) and we have a number of excellent resources that will likely help you process these features:
Hope this helps.
