AutoCAD Reader: Error opening file during version check,
  • Sep 29, 2014 3:56 PM UTC
  • 217 views
jamal
Forum|alt.badge.img+5
I have a simple workbench that converts CAD to lines. I got the error below when the workbench is run.
AutoCAD Reader: Error opening file '\\\\213.6.3.171\\Temp\\FMEInput\\Ayman_02.dwg' during version check
What might be the issue here?
Thank you
Best
Jamal
  • Sep 30, 2014 3:15 AM UTC
Hi Jamal,
One possible case is that the source data file doesn't exist in the specified path.
Firstly check if the path string is correct.
Takashi
jamal
  • Nov 12, 2014 9:29 PM UTC
Thank you very much Takashi,
The issue is resolved.
Best
Jamal
